Destination Tab
This
tab contains routing options for the Route Entry to User activity. All settings in this tab must be configured.
Note: Before configuring this tab or reading this help topic, we recommenced that you read Trustee Provider Configuration.
To open the Destination tab
- Add the Route Entry to User activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
- Under Routing Options in the Properties Pane, click the
folder icon to open the Destination tab of the Routing Activity Options dialog box.
To configure the Destination tab
- Under Configure where the entry should be routed, choose one of the following.
- Route to user's default folder: Routes entries to the user's default working folder, listed in the read-only property box under this option.
- Optional: Click Set user folder to define default user or group property token values like a user's default folder.
- Route to folder:
Routes entries to a specific folder in the repository. Click Browse to specify a folder or manually enter a folder path. Click the Token button (right arrow)
to use tokens. Entries can only be moved to a location in the repository specified. - Route to the user's folder in this folder collection: Routes entries to users using folder collections. Folder collections are lists of folder and user/group pairings that are different from a user's/group's default folder. This option only applies to the current activity and does not affect the user's default working folder. Learn more about Folder Collections.
- Select a folder collection from the Choose a folder collection drop-down menu. To create or modify a folder collection, select Manage Folder Collections.
- If the user is not in the selected folder collection, the entries are routed to the user's default folder instead. The default folder is listed in the read-only text box. To specify a new default folder, select Set user folder. Learn more about defining trustee information.
Example: You create a folder collection of folders for team leaders from several departments. By choosing the Team Leader folder collection, you can route entries to a person's team leader folder instead of his or her default folder.
