Delete Laserfiche Directory Trustee
This activity allows a user to delete a user or group from a Laserfiche Directory Server.
See the following options:
Activity Name
Activity Description
Server
Select the name of your Laserfiche Directory Server.
Trustee to Delete
Click the Select link and choose the user or group you wish to delete.
