Create Laserfiche Directory Group
This activity creates a group in the Laserfiche Directory Server.
See the following options:
Activity Name
Activity Description
Server
Select the name of your Laserfiche Directory Server.
Group Name
Type the name of the Group you wish to create.
Organization
Type the name of the Organization the Group will belong to or use the browse button
to choose your Organization.
Tokens for Create Laserfiche Directory Group
The Create Laserfiche Directory Group activity produces the following tokens.
| ID | The ID of the group created by the Create Laserfiche Directory Group activity. | %(CreateLaserficheDirectoryGroup_ID) |
| Display Name | The display name of the group created by the Create Laserfiche Directory Group activity. | %(CreateLaserficheDirectoryGroup_Display Name) |
| Account Name | The account name of the group created by the Create Laserfiche Directory Group activity. | %(CreateLaserficheDirectoryGroup_Account Name) |
| The e-mail address of the group created by the Create Laserfiche Directory Group activity. | %(CreateLaserficheDirectoryGroup_E-mail) | |
| Working Folder | The working folder for the group created by the Create Laserfiche Directory Group activity. | %(CreateLaserficheDirectoryGroup_Working Folder) |
| Default Folder | The default folder for the group created by the Create Laserfiche Directory Group activity. | %(CreateLaserficheDirectoryGroup_Default Folder) |
| Managers E-mail | The e-mail address(es) of the manager(s) of the groupcreated by the Create Laserfiche Directory Group activity. | %(CreateLaserficheDirectoryGroup_Managers E-mail) |
*The "CreateLaserficheDirectoryGroup" portion of the syntax changes to match the activity's name as specified in the Activity Name property box. Note that all non-alphanumeric characters, except underscores, are removed from the name.
