Set Entry Owner
This activity can make a user an entry's owner or remove an owner from an entry. A user that owns an entry automatically has the security permissions to manage the entry, even if the user does not otherwise have the relevant rights or privileges to that entry. Learn more about entry ownership.
Example: Laserfiche automatically makes scanner operators the owner of the documents they create (scan) in the repository. Use this activity to remove entry ownership from these documents so the scanner operators cannot modify them.
- Activity Name
- Activity Description
- Owner
- Set Owner For
Tokens for Set Entry Owner
The Set Entry Owner activity produces the following tokens.
| New User Name | The account name of the new entry owner. | %(SetEntryOwner_New User Name) |
| Old User Name | The account name of the entry's owner before the Set Entry Owner activity assigned a new owner. | %(SetEntryOwner_Old User Name) |
*The "SetEntryOwner" portion of the syntax changes to match the activity's name as specified in the Activity Name property box. All non-alphanumeric characters, except underscores, are removed from the name.
Example: If you rename the activity Assign-to-@Initiator, the syntax for the New User Name token will be %(AssigntoInitiator_New User Name).
