Conditional Parallel
This activity runs sequences of activities in parallel based on specified conditions. It contains two separate branches by default, each of which represents a discrete route for entries.
See an animation of this activity
Select the activity in the Designer Pane to configure the following:
See the following options:
Activity Name
Activity Description
Branch Configuration
The Conditional Parallel activity evaluates the conditions for each branch and performs those branches whose conditions are satisfied in parallel. It contains two separate branches by default, each of which represents a discrete route for entries.
To configure each branch
- Add the Conditional Parallel activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
- Click a branch in the Designer Pane.
Condition property box, click No condition set. Click here to create one. - In the condition editor, click any underlined text in the condition editor to choose from a variety of condition options. You can create as many conditions as you want by clicking Add condition. Right-click a condition for more options. Learn more about configuring conditions.
- Click OK.
- Add the activities you want each branch to perform by dragging them from the Toolbox Pane and dropping them in the branch.
Adding Branches
The Conditional Parallel activity contains two separate branches by default, each of which represents a discrete route for entries. You can add additional branches.
To add a branch
- Right-click the name of the activity in the Designer Pane.
- Select
Add Branch.
Deleting Branches
If you choose to add additional branches, you can delete them later. This activity must contain at least one branch.
To delete a branch
- Right-click a branch in the Designer Pane.
- Select
Delete.
- Enabling and Disabling Branches
