Sign Document
This activity signs a Laserfiche document as the Workflow User. See the token this activity produces.
Note: Digital signatures have reached end of life and creating new digital signatures is no longer supported. Existing digital signatures can still be viewed, validated, and deleted. For more information, see the End-of-Life Announcement for Laserfiche Digital Signatures.
ClosedHow does this activity look in the Designer Pane?
Note: If you export a workflow that includes a Sign Document activity, the signature's certificate will not be included in the export file.
Tokens for Sign Document
The Sign Document activity produces the following token.
Signature Id The signature's ID number %(SignDocument_Signature Id)
Note: Starting in 2026H1, the %(SignDocument_Signature Id) token always returns -1 because the Sign Document activity is deprecated.
*The "SignDocument" portion of the syntax changes to match the activity's name as specified in the Activity Name property box. Note that all non-alphanumeric characters, except underscores, are removed from the name. For example, if you rename the activity Apply "My Signature", the syntax for the Signature Id token will be %(ApplyMySignature_Signature Id).
