Change Starting Entry
This activity changes the starting entry to a specified entry, or updates the Entry Name and Entry Path tokens to reflect the entry’s current name and path. See the tokens this activity produces.
Note: All the activities listed below the Change Starting Entry activity in the Designer Pane act on the entry specified in this activity by default.
See the following options:
Activity Name
Activity Description
Entry
Tokens for Change Starting Entry
The Change Starting Entry activity produces the following tokens.
| PreviousEntry_Name | The name of the original starting entry. | %(ChangeStartingEntry_PreviousEntry_Name) |
| PreviousEntry_Id | The Laserfiche ID number of the original starting entry. | %(ChangeStartingEntry_PreviousEntry_Id) |
| PreviousEntry_Path | The folder path of the original starting entry. | %(ChangeStartingEntry_PreviousEntry_Path) |
| PreviousEntry_FullPath | The folder path of the original starting entry, including the entry's name in the path. | %(ChangeStartingEntry_PreviousEntry_FullPath) |
| PreviousEntry_Repository | The repository the original starting entry was in. | %(ChangeStartingEntry_PreviousEntry_Repository) |
| PreviousEntry_Server | The Laserfiche Server that contained the original starting entry. | %(ChangeStartingEntry_PreviousEntry_Server) |
| PrevousEntry_Guid | The GUID (Globally Unique Identifier) of the original starting entry. | %(ChangeStartingEntry_PreviousEntry_Guid) |
| OutputEntry_Name | The name of the starting entry specified by the Change Starting Entry activity. | %(ChangeStartingEntry_OutputEntry_Name) |
| OutputEntry_Id | The Laserfiche ID number of the starting entry specified by the Change Starting Entry activity. | %(ChangeStartingEntry_OutputEntry_Id) |
| OutputEntry_Path | The folder path of the starting entry specified by the Change Starting Entry activity. | %(ChangeStartingEntry_OutputEntry_Path) |
| OutputEntry_FullPath | The folder path of the starting entry specified by the Change Starting Entry activity, including the entry's name in the path. | %(ChangeStartingEntry_OutputEntry_FullPath) |
| OutputEntry_Repository | The repository that contains the starting entry specified by the Change Starting Entry activity. | %(ChangeStartingEntry_OutputEntry_Repository) |
| OutputEntry_Server | The Laserfiche Server that contains the starting entry specified by the Change Starting Entry activity. | %(ChangeStartingEntry_OutputEntry_Server) |
| OutputEntry_Guid | The GUID (Globally Unique Identifier) of the starting entry specified by the Change Starting Entry activity. | %(ChangeStartingEntry_OutputEntry_Guid) |
| EntryWasFound | Whether the new starting entry selected by the Change Starting Entry activity was successfully found in the Laserfiche repository. This token can have one of two values: True or False. | %(ChangeStartingEntry_EntryWasFound) |
*The "ChangeStartingEntry" portion of the syntax changes to match the activity's name as specified in the Activity Name property box. Note that all non-alphanumeric characters, except underscores, are removed from the name. For example, if you rename the activity 'Refresh' Tokens, the syntax for the PreviousEntry_Id token will be %(RefreshTokens_PreviousEntry_Id).
