Invoke Workflow
This activity starts a workflow from a Workflow Server.
- Select the activity in the Designer Pane to configure the following property boxes.
Note: If you have more than one connection profile for your workflow definition, this property box lets you specify which connection profile this activity will use.
Note: You can configure the default settings for the Invoke Workflow activity in the Activity Performance tab of the Advanced Server Options.
Note: In order to help prevent runaway workflows, more than 32 Invoke Workflow activities cannot be strung together.
at the top of the Properties Pane to view and configure these properties.
