Delete Shortcuts
This activity deletes all shortcuts linking to a specified entry. See the token this activity produces.
Activity Name
Activity Description
Delete Shortcuts From
Token for Delete Shortcuts
The Delete Shortcuts activity produces the following token.
| Shortcut Count | The number of shortcuts the Delete Shortcut activity deleted. | %(DeleteShortcuts_Shortcut Count) |
*The "DeleteShortcuts" portion of the syntax changes to match the activity's name as specified in the Activity Name property box. All non-alphanumeric characters, except underscores, are removed from the name.
Example: If you rename the activity "Remove-LinkDocs!," the syntax for the Shortcut Count token will be %(RemoveLinkDocs_Shortcut Count).
