Conditional Sequence
This activity performs the contained activities if its conditions are satisfied.
See an animation of this activity
Select the activity in the Designer Pane to configure the following:
Activity Name
Activity Description
Sequence Conditions
This property box defines the conditions for the Conditional Sequence activity. If the conditions are met, the activity will perform the sequence of activities contained within it. If the conditions are not met, the workflow will continue without running the activities contained in the Conditional Sequence activity.
To configure the Conditional Sequence activity
- Add the Conditional Sequence activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
Condition property box, click No condition set. Click here to create one. - A condition editor will appear. Click any underlined text in the condition editor to choose from a variety of condition options. You can create as many conditions as you want by clicking Add condition. Right-click a condition for more options. Learn more about configuring conditions.
- Click OK.
- Drag and drop activities into this activity.
