Retrieve Field Values
This activity retrieves field values from a Laserfiche entry and produces tokens for those values to be used by other activities in your workflow definition. See the tokens this activity produces.
- Activity Name
- Activity Description
- Fields
- Field Value Source
Tokens for Retrieve Field Values
The Retrieve Field Values activity produces the following tokens.
| Template Name | The name of the template assigned to the entry. | %(RetrieveFieldValues_Template Name) |
| Field Name | A token is created for each field retrieved. The token name is the same as the field name. If the field is a multi-value field, the field name is followed by _All. |
%(RetrieveFieldValues_Field1) %(RetrieveFieldValues_MultiValueField_All) |
*The "RetrieveFieldValues" portion of the syntax changes to match the activity's name as specified in the Activity Name property box. Note that all non-alphanumeric characters, except underscores, are removed from the name. For example, if you rename the activity Get: Info!, the syntax for the field named "Date" will be %(GetInfo_Date).
