Route Entry to Folder
This activity routes a Laserfiche entry to a specified folder. It can also:
- Assign a template to an entry.
- Populate a field.
- Add or remove tags to or from an entry.
- Send an e-mail.
- Use wait conditions.
- Activity Name
- Activity Description
- Routing Options
- Entry to Route
Tokens for Route Entry to Folder
The Route Entry to Folder activity produces the following tokens.
| RoutedEntry_Name | The name of the routed entry. | %(RouteEntrytoFolder_RoutedEntry_Name) |
| RoutedEntry_Id | The Laserfiche ID number of the routed entry. | %(RouteEntrytoFolder_RoutedEntry_Id) |
| RoutedEntry_Path | The folder path of the routed entry. | %(RouteEntrytoFolder_RoutedEntry_Path) |
| RoutedEntry_FullPath | The folder path of the routed entry, including the entry's name in the path. | %(RouteEntrytoFolder_RoutedEntry_FullPath) |
| RoutedEntry_Repository | The repository the routed entry is in. | %(RouteEntrytoFolder_RoutedEntry_Repository) |
| RoutedEntry_Server | The Laserfiche Server that contains the routed entry. | %(RouteEntrytoFolder_RoutedEntry_Server) |
| RoutedEntry_Guid | The GUID (Globally Unique Identifier) of the routed entry. | %(RouteEntrytoFolder_RoutedEntry_Guid) |
| RoutingFolder_Name | The name of the folder the Route Entry to Folder activity moved the entry into. | %(RouteEntrytoFolder_RoutingFolder_Name) |
| RoutingFolder_Id | The Laserfiche ID number of the folder the Route Entry to Folder activity moved the entry into. | %(RouteEntrytoFolder_RoutingFolder_Id) |
| RoutingFolder_Path | The folder path of the folder the Route Entry to Folder activity moved the entry into. | %(RouteEntrytoFolder_RoutingFolder_Path) |
| RoutingFolder_FullPath | The folder path of the folder the Route Entry to Folder activity moved the entry into, including the folder name in the path. | %(RouteEntrytoFolder_RoutingFolder_FullPath) |
| RoutingFolder_Repository | The repository that contains the folder the Route Entry to Folder activity moved the entry into. | %(RouteEntrytoFolder_RoutingFolder_Repository) |
| RoutingFolder_Server | The Laserfiche Server that contains the folder the Route Entry to Folder activity moved the entry into. | %(RouteEntrytoFolder_RoutingFolder_Server) |
| RoutingFolder_Guid | The GUID (Globally Unique Identifier) of the folder the Route Entry to Folder activity moved the entry into. | %(RouteEntrytoFolder_RoutingFolder_Guid) |
| Event Initially Satisfied | Whether the wait condition specified in the Route Entry to Folder activity was initially satisfied. This token can have one of two values: True or False. | %(RouteEntrytoFolder_Event Initially Satisfied) |
| Event Duration | How long it took for the activity's wait condition to be satisfied. | %(RouteEntrytoFolder_Event Duration) |
| Event Id | The event ID for the activity's wait condition being satisfied. | %(RouteEntrytoFolder_Event Id) |
| Event User | The user who satisfied the activity's wait condition. | %(RouteEntrytoFolder_Event User) |
| Event User SID | The SID (Security Identifier) of the user who satisfied the activity's wait condition. | %(RouteEntrytoFolder_Event User SID) |
| E-mail.Reminder Count | How many times the e-mail has been resent with the e-mail escalation feature. This token is only available when configuring an e-mail within a Routing activity. | %(E-mail.Reminder Count) |
| Parent | If an entry and the folder it is in (its parent folder) have the same field, this token represents the field value of the parent folder’s field. The token %(Parent:Fieldname) represents the value of a different parent field. These tokens can only be used with fields and are available only in the Fields tab of the Routing activities.
Note: You can also access all field tokens within the Routing activities. |
%(Parent) |
*The "RouteEntrytoFolder" portion of the syntax changes to match the activity's name as specified in the Activity Name property box. Note that all non-alphanumeric characters, except underscores, are removed from the name. For example, if you rename the activity Move to: Folder_A, the syntax for the RoutedEntry_Id token will be %(MovetoFolder_A_RoutedEntry_Id).
Note: The Routing activities also let you access fields that would normally only be available if you used a Retrieve Field Values activity. The syntax for these field tokens is: %(Fields.Field Name).
Note: The Routing activities create extra tokens while running that are used internally by the activity. These tokens appear in the Tokens tab of the workflow's instance details if you use the Track Tokens activity.
