New Entry Name
This property box determines the new entry name to be used by the Rename Entry activity.
To configure New Entry Name
  1. Add the Rename Entry activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
  3. Under ClosedNew Entry Name in the Properties Pane, enter the entry's new name. Click the Token button (right arrow) Token button to use tokens.
