Preferred Response Format
This property box lets you request what format the response from your HTTP Web Request or HTTP Form Post activity will come back in.
Note: Making requests does not ensure the Web service will honor them in its response.
To configure the response content format you prefer
  1. Add the HTTP Web Request or HTTP Form Post activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
  2. Select the activity.
  3. In the ClosedPreferred Response Format property box, choose a format from the drop-down menu.
  4. If you select Custom, a text box will appear for you to enter the content format type. Click the Token button (right arrow) Token button to use tokens.
