HTTP Form Post
Sends a multipart/form-data POST request to a Web service and returns the result in tokens. To configure this activity, you will need access to a Web service, its API, and a basic understanding of HTTP transactions.
Example: You could use this activity to automatically fill out an online venue request application form.
- Advanced Properties
Click the Advanced button
at the top of the Properties Pane to view and configure these properties.
Tokens for HTTP Form Post
The HTTP Form Post activity produces the following tokens.
| Content File | The file returned by the Web service in response to the HTTP web request. You can use this token in another HTTP Form Post activity to post a file to a form. | %(HTTPFormPost_Content File) |
| Content | The data returned by the form you are posting to. | %(HTTPFormPost_Content) |
| Content Length | The length of the response in characters or bytes. | %(HTTPFormPost_Content Length) |
| Response Status |
%(HTTPFormPost_Status) |
| Response Status Description | The description that accompanies the status code. | %(HTTPFormPost_Status Description) |
| Request Succeeded | Whether the HTTP form post succeeded or not. This token will have one of two values: "True" or "False." | %(HTTPFormPost_Succeeded) |
*"HTTPFormPost" will change to match the name specified in the Activity Name property box.
Note: All non-alphanumeric characters, except underscores, are removed from the name. For example, if you rename the activity "Fill out ^Form^," the syntax for the Content token will be: %(FilloutForm_Content).
