Web Service
This property box lets you specify which Web service the HTTP Web Request or HTTP Form Post activity will interact with.
To configure a Web service
- Add the HTTP Web Request or HTTP Form Post activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
Web Service in the Properties Pane, choose a server from the drop-down menu. - Optional: Click the refresh icon
to update the list of available servers.
Note: If the Web service you want to connect to is not listed, then select Manage servers. Follow the instructions to add a Web service.
