Advanced Options
This property box determines if the HTTP Web Request or HTTP Form Post activity will handle failed requests, cookie storage, and automatic redirection.
  1. Select the activity in the Designer Pane.
  2. Click the Advanced button at the top of the Properties Pane.
  3. In the ClosedAdvanced Options property box, select or clear the following options:
    • Report a warning if request fails: Select this checkbox to report a warning in the Message tab of the workflow's instance details if the request made by the activity fails.
    • Follow redirects: Select this checkbox to have the activity follow any redirects the Web service has configured.
    • Output new cookie container: Select this checkbox to create a new cookie container. This option will create a new session with this activity.
