Server
This property box lets you choose which Forms Server the Retrieve Business Process Variables activity will retrieve field values and business process information from.
To configure a server
- Add the Retrieve Business Process Variables activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
Server in the Properties Pane, choose a server from the drop-down menu. -
Optional: Click the refresh icon
to update the list of available servers.
Note: If the Forms Server you want to connect to is not configured to work with Workflow, then select Manage servers. Follow the instructions to add a Web service.
Note: You must specify your Workflow Server on the Forms Server Configuration page.
