Update Step Instructions
This activity updates the instructions for a Business Process Step activity. See the tokens this activity produces. This activity also updates the Business Process Step activity's Instructions token.
- Activity Name
- Activity Description
- New Instructions
- Step to Update
Tokens for Update Step Instructions
The Update Step Instructions activity produces the following token.
| Instructions | The new instructions assigned to the specified Business Process Step activity. | %(UpdateStepInstructions_Instructions) |
*"UpdateStepInstructions" will change to match the name specified in the Activity Name property box.
Note: All non-alphanumeric characters, except underscores, are removed from the name. For example, if you rename the activity Give*Instructions*, the syntax for the Instructions token will be: %(GiveInstructions_Instructions).
