Destination Path
This property box determines where the entries copied with the Replicate Entries activity are copied to.
To configure Destination Path
  1. Add the Replicate Entries activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
  3. Under ClosedDestination Path in the Properties Pane, type a location path, or click the Browse button (ellipsis) to browse for a folder. Alternatively, click the Token button (right arrow) Token button to use tokens.
  4. Note: You can only enter a destination within the Laserfiche repository defined in the Destination Repository property box.
  5. Select what should occur if the destination you select does not exist.
