Distributed Processing Scheduler
This property box lets you specify which Distributed Processing Scheduler will schedule the OCR tasks configured in the Schedule OCR activity. In a group of distributed processing machines, the scheduler machine divides OCR projects among the worker machines.
To specify a Distributed Processing Scheduler
- Add the Schedule OCR activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
Distributed Processing Scheduler in the Properties Pane, either: - Use the default scheduler as specified in the Distributed Processing node of the Workflow Administration Console.
- Choose a scheduler from the drop down menu. To add or manage schedulers, select Manage schedulers from the drop-down menu. Learn more about distributed processing servers.
