Documents to OCR
This property box for the Schedule OCR activity lets you add documents to the OCR queue. The documents specified here are sent as a single job to the Distributed Processing Scheduler.
Tip: In general, having your Distributed Processing Scheduler run fewer, larger jobs be faster than many, smaller jobs. However, for the best results, we recommend not sending more than 10,000 entries at once to the Distributed Processing Scheduler.
To select documents to OCR
  1. Add the Schedule OCR activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
  3. Under Documents to OCR in the Properties Pane, click Add to select documents.
  4. Choose an entry from the Select Entry dialog box. Repeat steps 3 and 4 to continue to add documents to OCR.
  5. Optional: To remove documents from this list, select the document you want to remove and click Remove in the Documents to OCR property box.
  6. Select the Include entries in subfolders checkbox to OCR the contents of any folders specified in the Documents to OCR property box. Note that this will OCR the contents of the folder's subfolders, all the way down the folder tree.
