Read JSON
This activity retrieves values from a JSON document. There are a variety of ways to define the JSON document.
See the following options:
Activity Name
Activity Description
JSON Source
Use this property box to specify the JSON document you want to process.
- Add the Read JSON activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
- In the JSON Source property box, specify the JSON document you want to process. If the JSON document is retrieved as part of a previous activity in the workflow, specify the desired token.
JPath Expression Tokens
Use this property box to configure the activity. Specify the JSON document you want to traverse and a JPath expression for how to traverse the JSON document.
To configure JSON information
- In the Properties property box, click New Token.
- Specify a token name.
- In JPath Expression, manually specify an appropriate JPath expression to traverse the JSON document and select values or click
to help you build an JPath expression. - Choose one of the following options:
- Create a token: Choose between choosing to create a new token
- Update token: or to store the result in an existing token.
- In the If multiple matches are found drop-down option, choose what happens when the specified JPath expression matches multiple nodes in the JSON document.
Note: Click the Click here to test the pattern link, to display the Test Input text box. Paste or type a sample JSON document to see the result of your JPath expression.
Example: The response from an HTTP Web Request activity can be a JSON document that contains an element or attribute with a Laserfiche document ID. A Read JSON activity can retrieve this document ID for use in a later step in the workflow.
Important: The Read JSON activity uses the Goessner JPath implementation .
