Scripting Language
This property box lets you choose which programming language the script(s) will be compiled in when a Script or SDK Script activity is run.
To configure Scripting Language
  1. Add a Script or SDK Script activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
  3. Under ClosedScripting Language in the Properties Pane select VB.NET or C# for your programming language.
Note: Changing the scripting language will not delete any scripts. But, only scripts written in the selected language will be run.
