Keyboard Shortcuts
The following list details the keyboard shortcuts in Quick Fields, the Quick Fields Administration Console, and Quick Fields Scanning.
Tip: Shortcuts are especially useful for quickly navigating through a large number of documents during the review process.
Tip: You can customize existing shortcuts and add new ones in Quick Fields only.
Quick Fields Shortcuts
Shortcut Description
ALT+UP ARROW Select a document's previous page.
ALT+DOWN ARROW Select a document's next page.
ALT+LEFT ARROW Select the previous document in the Document Revision Pane.
ALT+RIGHT ARROW Select the next document in the Document Revision Pane.
ALT+SHIFT+LEFT ARROW Display the previous document in the Document Revision Pane that has an error.
ALT+SHIFT+RIGHT ARROW Display the next document in the Document Revision Pane that has an error.
CTRL+G Display a specific page in a document.
CTRL+D Create a new document starting with the first selected page.
CTRL+SHIFT+D Create a new document from the selected pages.
CTRL+P Assign the selected document to a document class.
CTRL+ALT+P Assign all the documents in the selected folder.
CTRL+SHIFT+P Assign the selected document with the options last used to assign a document.
CTRL+T Open Configure Fields dialog box.
CTRL+ALT+RIGHT ARROW Rotate the selected thumbnails 90 degrees.
CTRL+ALT+LEFT ARROW Rotate the selected thumbnails 270 degrees.
CTRL+ALT+PLUS SIGN Make the thumbnails larger.
CTRL+ALT+MINUS SIGN Make the thumbnails smaller.
CTRL+SHIFT+S Start scanning.
CTRL+SHIFT+O Stop scanning.
CTRL+Z Undo the last action.
CTRL+Y Redo the last undone action.
CTRL+SHIFT+Z Undo a series of actions.
CTRL+SHIFT+Y Redo the last undone series of actions.
CTRL+X Cut.
CTRL+C Copy.
CTRL+V Paste.
DELETE Delete.
CTRL+N Create a new blank session.
CTRL+SHIFT+N Create a new session using the Create Session wizard.
CTRL+O Open an existing session.
CTRL+S Save the session.
CTRL+SHIFT+C Create a new document class.
CTRL+ALT+S Start a slide show.
ESC End the slide show.
CTRL+B Bookmark the selected item.
CTRL+LEFT ARROW Go to the previous bookmark.
CTRL+RIGHT ARROW Go to the next bookmark
F1 Opens Help for the selected item.
F2 Renames the selected item.
F3 Displays the Output Pane.
F4 Displays the Tasks Pane.
F5 Displays the Processing Information Pane.
F6 Displays the Session Configuration Pane.
F7 Displays the Document Revision Pane.
F8 Displays the Thumbnails Pane.
F10 Displays the Options dialog.
F11 Displays the Choose a Script Language dialog.
F12 Displays the Application Errors Pane.
CTRL+SHIFT+H Toggles Auto-Hide for the current pane.
Quick Fields Administration Console Shortcuts
Global
SHIFT+F1 Opens the help files in a new tab.
CTRL+SHIFT+~ Opens the About dialog box.
CTRL+ALT+1 Navigates to Sessions.
CTRL+ALT+2 Navigates to Document Classes.
CTRL+ALT+3 Navigates to Users and Groups.
F2 Renames the selected session or document class (when viewing Sessions or Document Classes only).
Session List
DELETE Deletes the selected session.
CTRL+ALT+I Imports a session.
CTRL+ALT+O Exports the selected session.
CTRL+ALT+D Displays the Details Pane.
CTRL+ALT+C Displays the Configure Columns dialog box.
SPACEBAR or ENTER Clicks the link or button selected. When the focus is on a sample image, it will open a larger view of that sample image.
Document Class List
DELETE Deletes the selected document class.
CTRL+ALT+I Imports a document class.
CTRL+ALT+O Exports the selected document class.
Users/Groups List
CTRL+ALT+A Opens the Add Users/Groups dialog box.
DELETE Deletes the selected user or group.
Sample Page Preview
SPACEBAR or ENTER Opens the sample image.
Quick Fields Scanning Shortcuts
Global
F1 Opens the Quick Fields Scanning help files.
F3 Displays the Document List Pane.
F4 Displays the Metadata Pane.
F5 Displays the Messages Pane.
F6 Displays the Image Pane.
F7 Displays the Text Pane.
F8 Displays the Thumbnails Pane (single document view only).
CTRL+F10 Displays the Options dialog box.
SHIFT+F10 Displays the Scan Settings dialog box.
CTRL+F1 Expands/Collapses the ribbon.
CTRL+F11 Resets the layout to default.
CTRL+SHIFT+S Starts or stops scanning.
CTRL+S Saves current workspace.
ALT+RIGHT Selects the next document in the Document List Pane.
ALT+LEFT Selects the previous document in the Document List Pane.
ALT+SHIFT+RIGHT Selects the next document containing validation errors in the Document List Pane.
ALT+SHIFT+LEFT Selects the previous document containing validation errors in the Document List Pane.
Start Page
ENTER Opens the selected session or workspace.
SPACEBAR Toggles a checkbox.
ESC Returns to the currently open workspace.
DELETE Deletes the selected workspace.
Documents List Pane
DELETE Deletes the selected documents.
F9 Toggles a compact layout for the Document List Pane.
CTRL+F Displays the document list filter.
ENTER Opens the selected document.
Metadata Pane
ENTER Moves through fields from top to bottom.
SHIFT+ENTER Moves through fields from bottom to top.
CTRL+N Creates a new subfolder under Storage Location.
SPACEBAR Fills the Date or Date/Time fields with the current date or date/time.
Pages View
CTRL+A Selects all the thumbnails of the selected document.
CTRL+X Cuts the selected page(s) of the selected document.
CTRL+V Pastes the previously cut page(s).
CTRL+D Creates a new document starting with the selected page.
CTRL+ALT+R Rotates the selected pages clockwise.
DELETE Deletes the selected pages.
Thumbnails Pane
CTRL+D Splits the selected pages into a new document.
Messages Pane
CTRL+F Opens the filter drop-down menu.
CTRL+E Exports the currently-visible messages.
Viewing a Document in the Image Pane
CTRL+PLUS SIGN Zoom in.
CTRL+MINUS SIGN Zoom out.
CTRL+SHIFT+PLUS SIGN Zoom in.
CTRL+SHIFT+MINUS SIGN Zoom out.
ESC Exits the single document view.
ALT+ DOWN ARROW Selects the next page.
ALT+UP ARROW Selects the previous page.
CTRL+G Places focus in the page number text box.
CTRL+T Stores the document.
CTRL+SHIFT+P Reprocesses the document.
CTRL+P Opens the Choose Document Class dialog to assign a document class.
You can view the Quick Fields Scanning shortcuts within Quick Fields Scanning by clicking the help button Help button at the top right of the ribbon and selecting Show shortcut keys.Click the arrow to the left of each section to collapse or expand that section's shortcut keys.
Shortcut Keys
Customizing Keyboard Shortcuts
Most actions in Quick Fields can be performed via a shortcut key. You can modify the default combinations by adding custom keyboard shortcuts.
Note: Keyboard customizations only affect the user who creates them and the machine on which they are created.
To assign a new shortcut to a command
  1. Select Customize Keyboard under Tools in the menu bar.
  2. Commands are organized into categories in the Shortcut Keys dialog box. Select a category from the drop-down box.
    Shortcut Key Dialog Box
  3. Select a command. Once selected, a description of the command will appear at the bottom of the dialog box.
  4. To assign the command a new shortcut, place your cursor in the text box under Press new shortcut key.
  5. Press a shortcut key combination.
    Example: Ctrl+W, CtrlL+Shift+Y, Ctrl+Shift+Alt+O
  6. Click Assign.
    Note: If the command already has a shortcut, it will be replaced.
To remove a shortcut from a command
  1. Select a category from the drop-down box.
  2. Select a command.
  3. If the command has a shortcut assigned to it, click Remove.
To permanently remove all custom shortcuts
  • Click Reset All. This process cannot be undone. All shortcut key combinations will return to their default state.
