Running Quick Fields Sessions
Once a Quick Fields session has been configured, you can save it locally or to a Quick Fields Server and open it again to process new sets of documents according to the same settings. You can adjust the scan source to suit the documents you want to capture, scan the documents, revise them after processing, determine how to handle unidentified documents, and store the documents in Laserfiche.
Note: Some options available to you depend on which add-ons your organization has purchased and the permissions that have been configured for you.
