Processes and Add-Ons
Quick Fields processes extract or add information to or from a page or document. For example, various processes available for Quick Fields can generate text from a document or a specific region of an image, determine whether a particular region is marked, extract information from a database, or apply annotations to the document. You can configure Quick Fields to store the document in Laserfiche according to the results of these processes.
Processes behave differently within the various stages of processing within sessions. In different stages, they may apply to all or specified pages of a document. In Identification, they are compared to criteria to determine whether a page should be assigned to a document class.
The basic version of Quick Fields allows users to retrieve documents from Laserfiche, perform image enhancements, generate text from documents, and send them to a Laserfiche repository. Additional processes and features can help automate many more functions using Quick Fields. You can read barcodes, match documents to forms, use multiple document classes, add annotations, and perform many other activities. To help you purchase the additional features best suited to your organization's needs, the additional features are grouped into packages called add-ons. When the add-ons are installed, the additional processes and features will be integrated into the interface. For this reason, the add-ons are described in the sections of these help files dedicated to the sections where they appear to the user.
Basic Quick Fields Installation
- Image Enhancements
- OmniPage OCR
- Universal Capture
- TWAIN Scanning
- Laserfiche Capture Engine
- Text Extraction
- Token Identification
- Page Size Identification
- Page Removal
- Token Accumulator
- Retrieve PDF Form Content
- Assign Token Value
- Generating images from PDFs using Universal Capture or Laserfiche Capture Engine
Other Process and Add-Ons
- Auto-Annotation
- Auto-OMR
- Barcode
- Bates Numbering
- Conditional
- Custom Process
- Document Classification
- Field Lookup
- Field Verification
- Fixed Annotation
- Form Alignment
- Form Extraction
- Form Identification
- Inline Pattern Matching Expressions in Tokens
- Lookup
- OmniPage Zone OCR
- Optical Mark Recognition
- Pattern Matching
- Permanent Stamp
- Real-Time Lookup
- Scripting
- Substitution
- Token Collector
- Token Retriever
- Token Verification
- Quick Fields Agent
