Introduction to Laserfiche Forms
Welcome to Laserfiche Forms!
Laserfiche Forms is a web application that allows users to create, manage, and route electronic forms. It can be used to collect, process, and analyze information, and to automate internal processes. Some of the features of Laserfiche Forms include:
  • Form design: Designers can create web forms with a drag-and-drop designer, and choose from a variety of field and data types.
  • Internal process automation: Designers can configure decision logic to route forms to the right approvers.
  • Data insights: Managers can analyze form data with custom reports and built-in charts.
  • Branding: Designers can apply custom themes and logos.
  • Security: Laserfiche Forms has built-in security features to help safeguard information.
  • Data prepopulation: Designers can push and pull data between apps to prepopulate fields.
  • Dynamic form sections: Designers can configure logic to dynamically show or hide sections of the form.
  • Modular rules and lookups: Designers can insert modular rules and lookups to populate and calculate data.
Laserfiche Forms can be used for a variety of purposes, such as streamlining hiring, employee reviews, and claim processing.
If you know the topic you're looking for, you can find it by browsing the table of contents on the left, by using the search in the top-right corner of the screen, or by making a selection from the choices below. Look under Automating Laserfiche Processes in the contents for the complete guide on using Laserfiche Forms.
ClosedSee a video on Laserfiche Forms
