Assign Geographical Location
The Assign Geographical Location activity lets you set or remove a repository entry's location.
Important: The Assign Geographical Location activity is available in Workflow 10.4.1 or later and requires Laserfiche Server 10.4 or later.
See the following options:
Activity Name
Activity Description
This menu lets you specify whether you're assigning or removing a geographical location. If you're assigning a location, you can also specify the values you're assigning for the location and location description.
To assign or remove a geographical location
- In the Properties Pane, select one of the following actions to take on the entry.
- Clear existing location data: Select this to remove the entry's geographical location properties. This will remove both the location and the location description.
- Assign new location data:
- Point: Specify the latitude and longitude coordinates for a point.
- Custom: Select Click here to enter a custom value for the Geography token to open a window where you can construct a JSON object that represents the geographical information you want to assign to the entry. You can use the token picker to select a token. Click OK when you're done. The JSON format for a single point representing by longitude and latitude is as follows (replace the sample longitude and latitude your own):
{ "Data": {
"Type": "Point",
"Subtype": "XY",
"Point": [-118.1883175, 33.8200657] } }
Note: While you can include a variety of geography information in the custom JSON object, Laserfiche client applications may only display single points on the default map integrations included in the document viewer.
- Under Location description, enter a human-readable description of the geographical location you're assigning. For example, you can enter a street address.
- Select Ignore empty inputs if you want existing location descriptions to be unchanged if the Location description field in this activity is empty. If Ignore empty inputs is cleared, Workflow will assign an empty location description if the Location description field in this activity is empty.
Assign Geographical Location To
