Configure Automatic Replies
This activity sends a request to a Microsoft Exchange Server to create an Automated Reply for the specified account.
Note: The activity supports Microsoft Exchange Server 2010 Service Pack 2 (SP2) and later.
Drag it from the Toolbox Pane and drop it in the Designer Pane.
To configure this activity, select the activity in the Designer Pane and modify the following property boxes in the Properties Pane.
Activity Name
Activity Description
Server
The
Server property box allows you to specify which Exchange server the Create Automatic Replies activity will connect to and create an Automatic Reply for.To connect to an Exchange server in the Server property box
- Add the Create Automatic Replies activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
- Under Server in the Properties Pane, select an Exchange server from the drop-down menu.
- Optional: To add, configure, or remove an Exchange server, select Manage Servers. Learn more about web services.
- Optional: Click the refresh icon
to update the list of Exchange servers available in the drop-down menu.
Item
The
Auto Reply Properties property box, for the Create Automatic Replies activity, lets you configure a message and time range for the specified account on the Exchange Server.- Add the Create Automatic Replies activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
- Under Auto Reply Properties in the Properties Pane, click anywhere in the property box.
- In the
Send Automatic Replies dialog you can set the time range and message for your Automatic Reply message. - Checking Use an existing time range... will first check if a time range is set up on the account and use it if available. If this box is unchecked the time range specified in the activity will always be used
- Checking Use an existing message... will use an existing internal and external message if one is configured on the account.
- Clicking the tab "Outside the Organization" will allow you to configure settings for sending automatic replies to accounts outside of your domain.
Note: If no external message is set up for the activity and one is not found on the server, external automatic replies will not be sent.
Account
Use this property box to specify an email address. Workflow will attempt to create the Automatic Reply for the account of the specified email address.
Important: This activity requires external configuration. Take note of the user account authenticating to the Web service specified in the Server property box. This account requires either Exchange permissions on individual folders in the mailbox or domain rights to impersonate the owner of an Exchange account.
