Create Exchange Item
This activity sends a request to a Microsoft Exchange Server to create a Microsoft Exchange task, appointment, or contact.
Note: The activity supports Microsoft Exchange Server 2010 Service Pack 2 (SP2) and later.
Drag it from the Toolbox Pane and drop it in the Designer Pane.
To configure this activity, select the activity in the Designer Pane and modify the following property boxes in the Properties Pane.
Activity Name
Activity Description
Server
The Server property box allows you to specify which Exchange server the Create Exchange Item activity will connect to and create an item on.
To connect to an Exchange server in the Server property box
- Add the Create Exchange Item activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
- Under Server in the Properties Pane, select an Exchange server from the drop-down menu.
- Optional: To add, configure, or remove an Exchange server, select Manage Servers. Learn more about web services.
- Optional: Click the refresh icon
to update the list of Exchange servers available in the drop-down menu.
Item
The Item property box, for the Create Exchange Item activity, lets you add a task, appointment, or contact to a Microsoft Exchange server.
- Under Item in the Properties Pane, click anywhere in the property box.
- In the Edit Exchange Item dialog box, use the Type drop-down menu to select whether you want to create a task, appointment, or contact in Exchange.
- Additional options in the Edit Exchange Item dialog box are available depending on what type of Exchange item you want to create.
- After entering a value for each column, click OK.
Assign To
Use this property box to specify an email address. Workflow will attempt to create the task, appointment, or contact in the mailbox of the specified email address. If left empty, Workflow will create the Exchange item in the mailbox of the account specified in the Server property box.
Advanced Properties
Click the Advanced button (
) at the top of the Properties Pane to view and configure these properties.
Use this property box to select an authentication method for Workflow when connecting to Microsoft Exchange Web Services. The selected method determines the type of external configuration that is required for the Workflow user account to create calendar items, tasks, and contacts in another user's Exchange account.
- Use Workflow user: Workflow authenticates to Exchange using the credentials specified in the Server property box. The owner of a recipient Exchange mailbox must grant the Create items and Folder visible permissions on the appropriate mailbox folder that the activity is attempting to access.
- Impersonate recipient: Workflow will authenticate to Exchange as the user account specified in the Assign To property box. This option requires a domain administrator to grant delegation rights in Active Directory to the account specified in the Server property box.
Important: This activity requires external configuration. Take note of the user account authenticating to the Web service specified in the Server property box. This account requires either Exchange permissions on individual folders in the mailbox or domain rights to impersonate the owner of an Exchange account. See the options in the Advanced property box.
