Create iCalendar File Activity
This activity creates an iCalendar file (.ICS) that you can import into any email client or calendar application that supports iCalendar Event and To-do items.
Example: Create an iCalendar File and send it as a File Attachment in an Email activity.
Drag it from the Toolbox Pane and drop it in the Designer Pane.
  • Activity Name
  • Activity Description
    3. Under in the Properties Pane, replace the default description.
  • iCalendar File Properties
    The iCalendar File Properties property box, for the Create iCalendar File activity, lets you specify the iCalendar properties you want include when generating an iCalendar file.
    1. Add the Create iCalendar File activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
    3. Under iCalendar File Properties in the Properties Pane, click anywhere in the property box.
    4. In the Edit iCalendar File dialog box, use the Type drop-down menu to select whether you want to create an iCalendar Event item or an iCalendar To-do item.
    5. Additional iCalendar properties are available.
    6. After entering a value for any additional properties, click OK.
Note: The iCalendar RFC specification is available at the Internet Engineering Task Force (IETF) website at http://tools.ietf.org/html/rfc5545.
