Delete Exchange Item
Drag it from the Toolbox Pane and drop it in the Designer Pane.
Activity Name
Activity Description
Item to delete
In the Item to delete property box you can choose which Exchange item you want to delete with the activity. You can only delete Exchange items that were created by a Create Exchange Item activity earlier in the workflow definition.
To delete an item
- Add the Delete Exchange Item activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
- Under Item to delete in the Properties Pane, click the Select link.
- In the
Select List Item dialog box, click the green arrow
next to the Exchange item you want to delete. - Click OK.
Tokens
The Delete Exchange Item activity produces the following token.
Name Description Sample Syntax* was deleted Whether the Exchange Item was deleted. This token can have one of two values: True or False. %(DeleteExchangeItem_was deleted) *The "DeleteExchangeItem" portion of the syntax changes to match the activity's name as specified in the Activity Name property box. All non-alphanumeric characters, except underscores, are removed from the name.
Example: If you rename the activity "Delete Task," the syntax for the was deleted token will be %(DeleteTask_was deleted).
Advanced
This property box allows you to configure the type of delete action when deleting a Microsoft Exchange task, appointment, or contact.
To configure the Advanced property box
- Select the Delete Exchange Item activity in the Designer Pane.
- Click the Advanced button (
) at the top of the Properties Pane. - Under
Advanced in the Properties Pane, select or clear the following options:
- Permanently purge item: Select this option to permanently purge the item from mailbox.
- More to Recover Deleted Items folder: Select this option to send the item to the user's Recover Deleted Items folder in Outlook.
- Move to Delete Items folder: Select this option to send the item to the user's Deleted Items folder in Outlook.
