Delete List Item
Activity Name
Activity Description
List Item to Delete
sharepoint, Sharepoint, SharePoint
In the
List Item to Delete property box you can choose which SharePoint® list item you want to delete with the Delete List Item activity. You can only delete SharePoint® list items that were created by a Create List Item activity earlier in the workflow definition. Note: Some SharePoint® lists do not allow their list items to be deleted. These lists include some of SharePoint®'s default lists and custom lists specifically configured to prevent item deletion.
To delete a list item
- Add the Delete List Item activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
- Under List Item to Delete in the Properties Pane, click the Select link.
- In the
Select List Item dialog box, click the green arrow
next to the SharePoint® list item you want to delete. - Click OK.
Tokens for Delete List Item
The Delete List Item activity produces the following tokens.
| List Name | The name of the SharePoint® list the item was deleted from. | %(DeleteListItem_List Name) |
| List Item ID | The ID of the deleted list item. | %(DeleteListItem_List Item Id) |
| Folder | The folder (if any) the list item was deleted from. This token is be replaced by a fully qualified URL. | %(DeleteListItem_Folder) |
| Root | The name of the host Web service. | %(DeleteListItem_Root) |
| Was Deleted | Whether the list item was deleted or not. This token can have one of two values: True or False. | %(DeleteListItem_WasDeleted) |
*The "DeleteListItem" portion of the syntax changes to match the activity's name as specified in the Activity Name property box. Note that all non-alphanumeric characters, except underscores, are removed from the name. For example, if you rename the activity Remove!SP* the syntax for the Folder token will be %(RemoveSP_Folder).
