Create List Item
This activity creates a new list item on a SharePoint® site. See the tokens this activity produces.
See the following options:
Activity Name
Activity Description
Server
sharepoint, Sharepoint, SharePoint
The
Server property box allows you to specify which SharePoint® site the Create List Item activity will connect to and create a list item on.
To connect to a SharePoint® site in the Web Service property box
- Add the Create List Item activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
- Under Server in the Properties Pane, select a SharePoint® server from the drop-down menu.
- Optional: To add, configure, or remove a SharePoint® server, select Manage Servers. Learn more about web services.
- Optional: Click the refresh icon
to update the list of SharePoint® servers available in the drop-down menu.
List Item
The List Item property box, for the Create List Item activity, lets you add a list item to a SharePoint® site.
To add a list item
- Under List Item in the Properties Pane, click anywhere in the property box.
- In the Edit List Item dialog box, use the List drop-down menu to select the SharePoint® list you want to add an item to.
- Optional: If the list you selected has subfolders, you can enter which folder you want to put your list item in next to Subfolders. Click the Token button (right arrow)
to use tokens to specify a subfolder. If you do not specify a subfolder, the item will be added to the main list. - Optional: If the list you selected is a document library, type a URL (such as a Web Access URL) next to URL. Click the Token button (right arrow)
to use tokens. A text file with a URL extension will be created as the document for the list item being created. This allows a user to navigate to the URL you specified by clicking the document library link in SharePoint®. - Click the Add/Remove Columns button.
- In the Choose Columns dialog box, select which columns you want your list item to have data in. Clear the checkboxes next to the columns you do not want to add data to.
- To find a specific column, start typing the column name next to Name. Click the red X
to clear your search results. - To only see the columns you have selected, click Only show selected columns. To see all columns, clear this checkbox.
- To select or clear all the columns shown, select or clear the Select/Clear all checkbox.
- After selecting the desired columns, click OK.
- In the Edit List Item dialog box, select a column and enter a value for the column under Value. Click the Token button (right arrow)
to use tokens. Repeat for each column you want to configure. - After entering a value for each column, click OK.
Note: You can type a file path next to URL to upload a copy of a document instead of specifying a URL. This document must be on your Workflow Server or a network drive that your Workflow Server can access. Note that files referenced in this way are not exported as part of a Workflow Import File.
Note: An unselected column will be given its default value, if one has been specified, or it will be left blank.
Note: What you can enter under Value depends on the column type. For example, Date Time-type columns will only allow you to enter dates and/or times and Trustee-type columns will let you enter a user name.
Tip: Hyperlink columns let you insert a link. Use this column type (in combination with the Generate Web Access URLs activity) to link to documents in Web Access.
Important: Required columns have an asterisk (*) next to their name. If you leave a required column's value blank, a validation warning will appear for the Create List Item activity. You cannot publish workflows with activities that have validation warnings.
Tokens for Create List Item
The Create List Items activity produces the following tokens.
| List Name | The name of the SharePoint® list the item was created on. | %(CreateListItem_List Name) |
| List Item ID | The ID of the new list item. | %(CreateListItem_List Item ID) |
| Folder | The folder (if any) the new list item was created in. This token is replaced by a fully qualified URL. | %(CreateListItem_Folder) |
| Root | The name of the host Web service. | %(CreateListItem_Root) |
*The "CreateListItem" portion of the syntax changes to match the activity's name as specified in the Activity Name property box. Note that all non-alphanumeric characters, except underscores, are removed from the name. For example, if you rename the activity Add~SP~ the syntax for the Folder token will be %(AddSP_Folder).
