PDF Metadata
This activity can read and write PDF metadata values.
Activity Name
Activity Description
PDF File
This property box determines which document will be modified.
To configure File to Attach
- Add the PDF Metadata activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
- Under PDF File in the Properties Pane, select and configure one of the following options in the drop-down menu next to Source.
- Workflow Server local disk: Select this option to choose an electronic document saved on the Workflow Server computer.
- Enter the desired electronic document's file path. Alternatively, click the Browse button (ellipsis)
to browse for a file on the Workflow Server, or click the Token button (right arrow)
to use tokens to specify a file path. - Server Attachment: Select this option to choose an electronic document attached to the Workflow Server. You can also attach documents to the Workflow Server with this option. These documents will be available to any Workflow Designer on the Workflow Server.
- Use the drop-down menu to select an electronic document that has been attached to the Workflow Server.
- Activity: Select this option to attach a PDF file created by an activity in your workflow.
- Click the Browse button (ellipsis)
to open the Select File dialog box. - Click the green arrow
next to the PDF file activity to attach. - Click OK.
Note: You must have file browsing enabled in the Workflow Administration Console to browse for a file on the Workflow Server local disk.
Note: If the document you want to attach is not in the drop-down list, you will need to attach the desired document to the Workflow Server. After you attach the desired document to the Workflow Server, the document will appear in the drop-down list.
Metadata Items
- Under Metadata Items, click Read to bring up the read PDF metadata item dialog or click write to bring up the write to a PDF metadata item dialog.
- Read a PDF Metadata Item
- In the Metadata Name text box, type in a value or click the token button (right arrow)
to use tokens for the metadata item that will be read. - Click the OK.
- Write a PDF Metadata Item
to use tokens for the metadata item that will be written. - In the Value text box, type in a value or click the token button (right arrow)
to use tokens for the value that will be used. - Click the OK.
Example: Valid metadata names include title, author, and subject. For information on additional PDF properties and metadata, see the Adobe Acrobat documentation.
