Update Exchange Item
Drag it from the Toolbox Pane and drop it in the Designer Pane.
Activity Name
Activity Description
Item to update
In the
Item to update property box you can choose which Exchange item you want to update with the activity. You can only update Exchange items that were created by a Create Exchange Item activity earlier in the workflow definition. To update an item
- Add the Update Exchange Item activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
- Under Item to Update in the Properties Pane, click the Select link.
- In the
Select List Item dialog box, click the green arrow
next to the Exchange item you want to update. - Click OK.
Item
The
Item property box lets you update a previously-created Exchange item.- Add the Update Exchange Item activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
- Under Item in the Properties Pane, click anywhere in the property box.
- In the Edit Exchange Item dialog box, modify options as desired.
- After entering a value for each column, click OK.
Assign To
Use this property box to specify an email address. Workflow will attempt to create the task, appointment, or contact in the mailbox of the specified email address.
Tokens
The Update Exchange Item activity produces the following token.
Name Description Sample Syntax* was updated Whether the Exchange Item was updated. This token can have one of two values: True or False. %(UpdateExchangeItem_was updated) *The "UpdateExchangeItem" portion of the syntax changes to match the activity's name as specified in the Activity Name property box. All non-alphanumeric characters, except underscores, are removed from the name.
Example: If you rename the activity "Update Task," the syntax for the was updated token will be %(UpdateTask_was updated).
