Version Control
This activity places documents under version control and can set a version comment and labels.
Activity Name
Activity Description
Options
In the Options property box, add a comment and labels for the current version of a document.
To set a comment or version label
- Under Comment, specify the desired comment. The activity will apply the comment to the current version of the document.
- Under Version Labels, specify any labels you want to assign to the version.
Document
