Workflow Description
You can type a description of your workflow definition in this property box. Providing a description for a workflow helps you remember what the workflow does.
Note: You can also specify a Workflow Description in the Publishing Wizard.
To add a workflow description
  1. Open an existing or new workflow definition.
    • To open an existing, unpublished workflow definition, select File from the main menu and click open.
    • To open an existing, published workflow definition, select Workflow from the main menu and click View Workflows. Alternatively, double-click a workflow listed in the Rule Manager.
    • To open a new workflow, click the new workflow button in the toolbar. Alternatively, select File from the main menu, point to New, and select Workflow.
  2. Select a blank spot in the Designer Pane.
  3. Under ClosedWorkflow Description in the Properties Pane, type a description.
