Download Electronic Document
This activity downloads the electronic file associated with a Laserfiche electronic document. The electronic file is available as a token.
Example: Retrieve the electronic file associated with a Laserfiche document and use the token containing the electronic file in the attachment field of an Email activity).
See the following options:
Activity Name
Activity Description
Download From
Tokens
The Download Electronic Document activity produces the following token.
Name Description Sample Syntax* Result File The electronic file associated with the Laserfiche document. %(DownloadElectronicDocument_Result File) File Name The file name of the electronic file. %(DownloadElectronicDocument_FileName) Extension The file extension of the electronic file. %(DownloadElectronicDocument_Extension) Mimetype The mime type of the electronic file. %(DownloadElectronicDocument_Mimetype) Has Electronic Document Whether there is an electronic file associated with the Laserfiche document. %(DownloadElectronicDocument_HasElectronicDocument) *The "DownloadElectronicDocument" portion of the syntax changes to match the activity's name as specified in the Activity Name property box. All non-alphanumeric characters, except underscores, are removed from the name.
Example: If you rename the activity "Download-ElectronicDocument!," the syntax for the Result File token will be %(DownloadElectronicDocument_Result File).
