Set Records Management Properties
This activity assigns records management properties to a record in the repository. It lets you change properties like event dates, cutoffs, and retention schedules. However, it cannot create records, cutoff instructions, or retention schedules.
This activity is particularly useful for scenarios like the following:
- Setting filing dates on documents that have been newly uploaded but whose actual filing dates are before the upload date. The repository will assign newly uploaded documents a default filing date that is the same as the upload date, but you can run a workflow after the upload to change the upload date to the actual filing date.
- Add holds to records that are part of an active audit in bulk. You can automate this by creating a workflow that finds these documents using a common criterion (such as a field value) and applying the Set Records Management Properties activity with an Add Hold action. When the audit is over, you can also remove holds from those items using a workflow.
- With the Set Records Management Activity, you can automatically assign cutoff instructions or retention schedules to these documents based on where they are located in the repository or on their metadata, even if they are not located in a record series or record folder. This is key in flexible records management, where cutoff instructions and retention schedules can be directly assigned to documents that are not in record series. Under flexible records management, more documents will potentially be in a folder structure where they do not inherit cutoff instructions or retention schedules from their parent folders.
Key Features
Each Set Records Management Properties activities performs one records management action. To perform multiple actions, use multiple Set Records Management Properties activities.
The Set Records Management Properties activity lets you apply changes to all entries found in a Find Entries activity, without having to use a For Each Entry loop.
Important: This activity can only be used with Laserfiche Server 10.4 and later. Using this activity with earlier versions of Laserfiche Server may cause unexpected behavior.
See the following options:
Activity Name
Activity Description
Action
This menu lets you specify the records management property you want to assign to the entry.
To select a records management property
- In the Properties Pane, select one of the following actions to take on the entry.
- Set Filing Date: Enter a filing date to assign to the entry. Use tokens to construct the filing date.
- Set Event Date: Click on the empty box. Select an event in the dialog that appears and assign a date value. You can also add or remove events from the displayed list of events.
- Cutoff: Cut off an entry.
- Uncutoff: Un-cut off an entry.
- Set Retention Schedule: Assign an existing retention schedule to the entry.
- Add Hold: Add a hold to the entry, with a reason and a due date.
- Remove Hold: Either remove all holds from the entry or only remove holds that have a certain reason.
- Assign Cutoff Instruction: Select an existing cutoff instruction to be applied to the entry.
Set Properties On
appropriate property box, choose which entry the activity will act on. - Starting Entry: The entry the workflow began with.
