Escalation Branches
The Escalation activity contains two branches by default: a primary branch and an Closedescalation branch. See the token the escalation branch produces.
Note: When the primary branch has completed, no new escalation branches will begin, but all currently running escalation branches must complete for the workflow to continue. ClosedShow me an example.
Tip: You can add escalation branches.
An escalation branch defines the routing criteria for an entry after a wait time is met. The activities contained in an escalation branch will only be performed if:
  • The branch's wait time is met.
  • The primary escalation branch has not been completed.
To configure an escalation branch
  1. Add the Escalation activity to your workflow by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
  2. Select an escalation branch in the Designer Pane.
  3. Drag and drop activities into the branch.
  4. Under ClosedInitial Wait in the Properties Pane, configure when the escalation branch will run.
    • Escalate after: Type in a number or use the scroll box (up-and-down arrows) to configure the amount of time (in days, hours, and/or minutes) before the escalation branch will run. Alternatively, click the token button (right arrow) Token button to use tokens.
    • Optional: Select Exclude weekends and holidays to count only business days in the Escalate after calculations.
    • Escalate on: Type in the date and time the escalation branch will run, or click the calendar icon to choose a date from a calendar. Alternatively, click the token button (right arrow) Token button to use tokens.
  5. Optional: Under ClosedRepeat Options, configure how many times and how often the escalation branch will repeat.
    • Select Run branch multiple times to have the escalation branch repeat if the primary branch has not been completed.
      1. Under Between each run, wait, type in a number or use the scroll box (up-and-down arrows) to configure the amount of time before the escalation branch will repeat. Alternatively, click the token button (right arrow) Token button to use tokens.
      2. Note: The wait time between each repetition of an escalation branch starts after the escalation branch last finished. For example, an escalation branch contains an Email and a Wait Condition activity and is set to repeat after one hour. The branch will repeat one hour after the wait condition is met, not one hour after the escalation branch started.
      3. Click Day(s) to select a unit of time (minutes, hours, days, or weeks) from the drop-down menu.
      4. Optional: Select Exclude weekends and holidays to count only business days.
      5. Next to Run up to, type in a number or use the scroll box (up-and-down arrows) to configure how many times the escalation branch will run if all currently running branches do not finish. Click the token button (right arrow) Token button to use tokens.
