Insert Data
This activity inserts the specified rows into a database.
  • Activity Name
  • Activity Description
  • Data Source
    This property box determines which data source the activity will use.
    To select a data source
    1. Add a Custom Query, Insert Data, Query Data, or Update Data activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
    3. Under ClosedData Source in the Properties Pane, select a data source from the drop-down menu.
    4. Note: Because the Workflow Server performs the data-source queries, you must create all data sources on the Workflow Server. Services cannot access mapped drives when you are setting up the data source.
    5. Optional: To add, configure, remove, or test a connection to an external data source, select Manage Data Sources from the drop-down menu. Learn more about data source administration.
    6. Optional: Click the refresh icon to update the list of data sources available in the drop-down menu.
  • Data to Insert
    This property box determines what row values will be inserted into a database with the Insert Data activity.
    Note: You must configure the Data Source property box before configuring this property box.
    To configure Data to Insert
    1. Add the Insert Data activity to your workflow definition by dragging it from the Toolbox Pane and dropping it in the Designer Pane.
    3. Under Data to Insert in the Properties Pane, select a table from the drop-down menu.
    4. Optional: Click Refresh to update the list of tables, if you have made changes to the data source.
    5. Optional:Click Create Identity Token to retrieve the identifier of the inserted rows.
    6. Click Set Values or anywhere in the dark gray box, to open the ClosedData to Insert dialog box.
    7. Select the boxes next to the Columns for which you want to specify values in the inserted row. Hold down the SHIFT or CTRL key to select multiple rows at once.
    8. Type in a value next to the Columns you selected, or click the Token button (right arrow) Token button to use tokens.
    9. Tip: To replace a token that has a blank value with "DB.NULL," apply the NULL token formatting expression.To always set a column's value to "DB.NULL", insert "%(DB.NULL)".
    10. Click OK.
  • Query Options
    This property box allows you to specify a custom timeout for data query activities.
    To specify a custom timeout
    3. Under ClosedQuery Options in the Properties Pane, select the Specify a custom timeout check box and specify the desired timeout value in seconds.
    Note: The default timeout value is 30 seconds.
Data Source
This property box determines which data source the Custom Query, Insert Data, Query Data, and Update Data activities will use.
  3. Under Data Source in the Properties Pane, select a data source from the drop-down menu.
  5. Optional: To add, configure, remove, or test a connection to an external data source, select Manage Data Sources from the drop-down menu. Learn more about administering data sources.
Data to Insert
  5. Click Set Values or anywhere in the dark gray box, to open the Data to Insert dialog box.
  6. Select the boxes next to the Columns for which you want to specify values in the inserted row. Hold down the SHIFT or CTRL key to select multiple rows at once.
  7. Type in a value next to the Columns you selected, or click the Token button (right arrow) Token button to use tokens.
  8. Tip: If you want a token to be replaced by DB.NULL in the case that the token's value is blank (the empty string), apply the NULL token formatting expression. If you want to set a column's value to DB.NULL regardless, insert the NULL token: %(DB.NULL).
  9. Click OK.
